Tuscon will not run loud squeal when trying to start / run. 35,000 mil
Tried removing serpentine belt and engine makes the same squealing noise when trying to start. p052 code
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Please verify the ODBII code.
Looking at Hyundai codes it is not listed and online there are OBDII P0052 codes, but no P052 codes.
P0052 refers to a heated Oxygen sensor, bank 2 sensor 1 problem.
Only trouble is your engine only has Bank 1 sensor 1 and Bank 1 sensor 2 which would cause P0030 and P0036 codes unless the code is a Hyundai specific OBDII code
Here's an image showing the location of the two sensors in your vehicle, just in case it is a loose or fractured wire connection to the sensor(s).
(click on image)
Here's a link showing the possible causes for a P052A code.
Here's an image showing the location of some of the sensors mentioned for the code.
(click to enlarge)
Bu yanıt yardımcı oldu mu?
It’s showing P052A.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 77
Hi @minnesotatuscon,
What year model and engine size and type (gas, diesel) is the vehicle?
jayeff tarafından
2017 Hyundai Tuscon 2.0 engine
Minnesota Tuscon tarafından
