Ana içeriğe geç
AC compressor clutch not engaging
It has enough freon, but wont engage. Not sure how to fix or even troubleshoot
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Yorum
@oldturkey03, would you have the Honda Accord HVAC troubleshooting manual for a 2012 Honda Accord SE?
Thank you, Bigfish.
tarafından
@bigfishtanner I just checked and the latest Accord manual I have is for the 2010
tarafından
Thank you @oldturkey03! The self-diagnostic procedure showed an open evaporator temperature sensor circuit. I was taking the sensor out and found the last person bent one of the two pins over in the connector.
tarafından
I checked the 7.5 fuse and the compressor relay both checked out good but when I checked the high pressure a/c port I got a mini screw driver and tap the port no freon fizzed out, Could this be my problem as to why the a/c clutch isn't engaging??
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @augustavan81723
Check if the 7.5A fuse # 20 (marked as MG clutch - magnetic clutch) in the engine bay fuse block is OK.
Magnetic clutch is the term used for the AC compressor clutch, presumably because it is electrically operated
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Fuse 20 does not appear to be blown or corroded
tarafından
Yorum Ekle
@augustavan81723 since you checked the fuse you know that it at least should have power. I suggest that you next use the self diagnostic function for your HVAC. Here is how to do that.
Resim
Resim
Automotive AC are pretty complex so it will be difficult to go through each step on here. Use the HVAC part of the SM for your checks and let us know what you find out and where/if you get stuck. Honda Accord HVAC
After the self diagnostics, my next step would be check the clutch itself. if the tests all came back looking good.
Puan 1
Yorum Ekle
You'll also want to check the relay, if the fuse is good. Sometimes the high/low-pressure switch could be bad, causing the compressor not to engage.
Puan 0
Yorum Ekle
Yanıtını ekle
August A Vanden Top sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 38
Son 30 gün: 274
Her zaman: 6,863
