Ana içeriğe geç
The first generation of the Chevrolet Aveo, identifiable by the internal code T200, the T250 being a facelifted model. This vehicle is also sold as a Pontiac G3, Daewoo Kalos or Pontiac Wave.
Why noise is coming while driving from front suspension
While driving a car noise coming from suspension
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @vishwanath39167
There may be a problem with the front shock absorbers.
Try the following:
Park the car on level ground, switch off the engine and apply the handbrake.
Go to a front corner of the car (either side) and push down as hard as you can on the body of the car and then let go.
Do this three or four times in a row to set up a rocking motion in the car and then after the fourth push, stop pushing and check if the car returns to its normal position with maybe one little bounce and then stops (without you touching it) or continues to bounce up and down a few more times.
If it continues then there's a problem with the shock absorber on that side.
Do the same on the other side and check.
If there is a problem here's a video that may help if it is a leaking shock absorber. .
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
VISHWANATH GOPAL NAMJOSHI sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 150
