Ana içeriğe geç
The VLT 1000 desktop fan has four blades with a diameter of 30 cm. It is made of stainless steel and has 3 speed settings.
Electric wire burn want to replace with new wire.
Want to replace new wire so help me with main neutral and earth connection
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
@ivaanmaran67435 post some pictures of where the wires are connected now. That way we can see what you see and hopefully help you with that. Adding images to an existing question
tarafından
I agree Ivaanmaran above. Question. Did the wire burn occur on its own or was the cord next to an hot object?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Dear Ivaan Marandi and Eva Marandi,
If your cable is not compatible with the voltage you need, please try replacing it with a cable that matches the required voltage. Additionally, consider changing the fuses in the cable socket and try again.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
IVAAN MARANDI AND EVA MARANDI sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 73
