Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Soru Tümünü görüntüle
Soru Kapandı
iPhone shows apple sign then loading circle
Ok so i did a glass replacenent and everything was fine exept the touch on the right side of the screen was not working very good so i removed the glass/lcd out to reconnect the cables and now when it turns on it shows the apple sign then after about 4 or 5 minutes it only shows the little loading circle. Need help this is my Managers phone....
Bu iyi bir soru mu?
Puan 0
4 Yorum
Did you back up the data on the phone? A restore may be necessary.
tarafından
Yes i did all that ... Held the home button then plug in, then the power button thing and it restored then just went back to charging sign the when it turned back on it still does the same thing
tarafından
Is it somthing i did while changing the glass??
tarafından
I think i messed it up .... I chipped a little peice of the little switch connecter off bout the with of a razor any way to fix that.... It happond during second removel to check the connection...
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Most probably connector 3 isn't in correctly. This happened to me when replacing the screen. I think it happens because the phone cannot boot without the proximity sensor.
To fix it just remove the front panel (digitizer+frame+lcd) and make sure connector 3 is correctly inserted! You should only see the darker copper, not the shinny bit!!
In addition, you made need a new screen as it may be the screen that is making the right hand side not work. Not the connection
Hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
You are great , i have been looking for the solution since two days, and you helped me alot. thanks again
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 1,030
