Ana içeriğe geç
Apple'ın ARM tabanlı M1 SoC'sini (8 çekirdekli CPU ve 8 çekirdeğe kadar GPU ile) içeren ilk 13 inç MacBook Air için onarım rehberleri, destek ve sorun giderme bilgileri. Kasım 2020'de piyasaya sürülmüştür ve A2337 veya EMC 3598 model numaralarıyla tanımlanır.
Keyboard and Trackpad stopped working
Hi! I have a MacBook Air M1 (2020) and after two months of my warranty expiration the keyboard and the trackpad suddenly stopped working. No liquid was spilled and no other damage was made.
The backlit of the keyboard works but the keyboard and the trackpad are both dead. If I connect an external keyboard and mouse they work fine (also if I press the caps lock on the external keyboard the led on the internal keyboard does not lit up).
I tried everything on software level with no luck. I opened the laptop and cleaned all the connectors with isopropyl alcohol but nothing happened. The ribbon cable and the connectors have no visible damage. Also I disconnected the keyboard connector from the board and left only the trackpad part of the ribbon connected with no result.
Is it worth to give $20-$30 try a new ribbon or it may be a motherboard problem? Apple said that the cost of the repair could go up to $600.
Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Both the keyboard and trackpad signals travel to the logic board over the one cable assembly MacBook Air 13" (A2179, A2337 2020) Trackpad Cable so it’s worth the expense to replace it first.
But before we do that how does the battery look? Compare it to the images in this guide MacBook Air 13" 2020 Sonu Batarya Değişimi as a puffed up battery can cause problems with the cable.
Was someone inside before this happened? One other possibility is a damaged logic board connector so when you take the cable off really inspect the contact pins didn’t get damaged on the board side and I would also check the cable end side as well.
Replace a torn or damaged cable that connects the trackpad and keyboard to the logic board compatible with the model A2179 or A2337 2020 13 inch MacBook Air laptop. Part #821-02663. Görseli
Ürün
$14.99
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
The battery is flat like the one in the pictures. I have this laptop from day one and I only opened it, after the problem. I will order the ribbon cable for a start as there is no visible damage on the logic board connector.
Thank you for your reply
tarafından
im also having this issue, flex was replaced, but trackpad is unresponsive, tried new trackpad and works, but is there any way to repair current trackpad?
tarafından
@robergza - Anything is possible! It comes down to skills and availability of the needed damaged element.
Most people just don’t have the very deep micro-electronics skills to reverse engineer the circuit and identify the components. Remember the Trackpad/Touchpad is not documented (Blackbox) even in the schematics and board view drawings which have found their way to the free world! Lastly, some of the components are programmed which will require tools to program them.
Basically, the cost of the time and tools is more expensive that just replacing the part. Yes, it sucks! Please join the Right to Repair movement!
tarafından
Yorum Ekle
Yanıtını ekle
Tasos Ionas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 46
Her zaman: 2,069
