My laptop is not starting charging
Bu iyi bir soru mu?
@mobilezone8947 start off with the simple things. First you want to check your power supply. Make sure it has the proper voltages. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. After that you need to check and see if your motherboard even gets power. For that of course, you need to open it up. This teardown Packard Bell EasyNote TK87-JO-050PL Teardown can help you with this. Post Some good pictures of what you see. That way we can see what you see Adding images to an existing question
You should also consider replacing the battery. A depleted battery can no longer be charged.
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Kılavuz
Zorluk:
Orta
10 minutes
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 293
Mi portátil tiene buena la batería, pero no le entra corriente. La fuente funciona, cuando la conecto da los 19v, pero no enciende el led indicador de carga.
Alexander Galano tarafından
