Ana içeriğe geç
Samsung RF24FSEDB, tezgah derinliği tasarımı, parmak izi bırakmayan yüzeyi, ayrı buharlaştırıcılara sahip Twin Cooling Plus sistemi, Power Freeze ve Power Cool seçenekleri ve LED aydınlatması ile öne çıkan 665 litrelik (23.5 cu. ft.) bir French Door buzdolabıdır.
Ice maker no longer working
My ice maker suddenly stopped working. I replaced the filter and the ice maker water valve. The main water supply works fine and the appliance does produce water just not ice. Does anyone know what else the problem might be?
Thanks in advance.
Paul Burnett
Update (08/27/23)
By the way, the model # is RF4289HARS/XAA.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @paulburnet63747
Here's the fast track troubleshooting sheet for the refrigerator that may help.
Perform the Self Diagnosis check as shown on the first page and check if there are any error codes being displayed.
The error codes and their meanings are shown on p.4.
There's also a Heat Release I/M Test Mode on p.2 which you can try as it checks if the ice maker thermistor, harvest motor and water valve are OK
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks for your reply. I'll try these tests and see if they correct the problem.
tarafından
Yorum Ekle
Yanıtını ekle
Paul Burnett sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 422
