Ipad 6 wifi not charging after battery replacement
I have an ipad 6 wifi that won't charge after a battery replacement, A USB power meter says the device is only drawing 0.075A of current when turned on. When booting it draws 0.088A then drops down to 0.01A. Once boot finishes and the device is on it returns to 0.075A
Update (08/31/23)
I took the ipad apart again and noticed that the HDQ pin on the motherboard side of the connector was pushed in slightly and not making contact. A quick bend back to shape fixed it although I did order a spare connector just in case.
Bu iyi bir soru mu?
1 Yorum
Why did the battery initially need replacing? Where did you source the battery from? Did you insert the guitar pick in the actual battery connector or off to the side of it?
Jesse Hooton tarafından
