Ana içeriğe geç
Find repair and more information about the Samsung RB195AB** refrigerator, a 2008 model with bottom freezer, door access, and features like automatic defrost and an anti-sweat heater switch. This page covers information for model numbers matching the pattern RB195AB**.
Samsung Model RB195ABBP display not working
Resim
Resim
Resim
The display on my Model RB195ABBP stopped functioning properly. The fridge works. However, the temperature for both the fridge and the freezer no longer display. Instead, I see two flashing blue short lines. I've tried unplugging and replugging as well as turning off the breaker for a few minutes with no succces. I have attached some photos and a video.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @nicjunior
There are no images attached to your question.
Looking at the schematic it may be a problem with either the display board, the cable connection (at either end) between the display board and the main control board or the main control board.
Are the temperatures in the refrigerator and freezer compartments OK? Place an appropriate thermometer in each compartment and check if the temps are approximately 39°F (3°- 4°C) refrigerator and 0°F (-18°C).
If is it determined that a "board" may be the problem, unfortunately I cannot find a parts list for the model that includes the boards, only some other parts for the model. Hopefully there may be a board number on the board itself. It may show as DA-97 ???????? but maybe not.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thank you, Jayesh, for your answer. I did upload some pictures. I'm not sure why they are not attached to my post.
In any case, I will try to locate where the display board is to get a parts number. Hopefully, replacing it is something that's easy enough for me to do.
tarafından
Did you ever find solution for this... Have samme issue here
tarafından
Yorum Ekle
Yanıtını ekle
Nic Junior sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 624
