Ana içeriğe geç
15,6 inç diyagonal LCD ekrana sahip Dell Inspiron dizüstü bilgisayar
How to check power socket
while powring on with wire its not showing power on anp pressing hard its getting charged
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @amitvirani
Here's the service manual for the laptop.
Go to p.79 to view the procedure to remove/replace the power adapter port.
You only have to dis-assemble the laptop far enough so that you can safely unplug the port's output cable from the motherboard.
Once that is done use an Ohmmeter (or a voltmeter), to prove continuity of the connection between the port input and the red and black wires on the cable plug on the output side of the port.
If the port is faulty it cannot be repaired. It has to be replaced.
Search online for KD4T9 to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Amit Virani sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 339
