Ana içeriğe geç
the Bluebird Sylphy G10 (N16) was sold as the Sunny Neo in Thailand and as the Sunny in Hong Kong, Kenya, Singapore, Sri Lanka and the People's Republic of China.
My car sunny 2005 engine check light on
I have check light problem, i was check all my spark plugs and coils and i also checked computer there is cods P0350
P0304 but still check light on please help me for solving problem
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
5 Yorum:
@waqasbajwa67 how did you check your spark plugs and your coil? Hopefully you changed your plugs….:-)
tarafından
A P0350 indicates that the Powertrain Control Module (PCM) has detected a malfunction in the circuit of one or more of the engine's ignition coils.
tarafından
I'm not familiar with this car, but if it has individual coils for each cylinder then I'd start with replacing the coil on cylinder #4, since the other code, P0304, indicates a misfire on cylinder 4. At the very least you could try swapping #4 coil with another cylinder and see if the misfire follows it.
tarafından
I have check engine light problem car racing during the drive suddenly showing check engine light and accelerator not working speed reduce 10-20 KM what's the problem
tarafından
@awladhossain You will need to get the car scanned for whatever trouble codes are causing the check engine light to turn on. Here in the US most auto parts stores will scan your car for free, but if that's not a service provided where you live you can buy an inexpensive bluetooth OBD-II device that can be read with a free app on your phone.
Best if you start your own question and add the trouble code information when you get it.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
The P0304 code means that cylinder #4 is misfiring or is randomly misfiring. The P0350 code means that the Powertrain Control Model (PCM) has detected a problem with the primary or secondary circuit of one or multiple ignition coils or ignition coil packs in your engine.
The P0304 code is a serious engine issue that requires immediate attention. A misfire is the absence of a full combustion event on a given cylinder as expected.
Here are some possible causes of a P0304 code:
  • A faulty ignition coil, spark plug, or wire
  • Loose fitting electrical connectors
  • Broken or disconnected vacuum hoses
  • The engine is dirty or has low oil pressure
Here are some possible causes of a P0350 code:
  • A problem with the electrical circuit
  • Damaged or loose connection of the spark plug wires
  • A faulty PCM
The most common symptom of a misfiring engine is a loss of power. The engine may also run rough, be difficult to start, or stall completely.
Here are some repairs that can fix a P0304 code:
  • Replace the spark plugs
  • Replace the cap and rotor, coil pack, or plug wires
  • Inspect the wires around the spark plugs for damage and loose connections
  • Replace a faulty fuel injector
  • Replace a worn ignition wire or a bad coil
  • Repair engine mechanical issues
  • Fix air leaks
  • Repair fueling faults
  • The P0350 code indicates that the Powertrain Control Module (PCM) has detected a malfunction in the circuit of one or more of the engine's ignition coils. The code is set when the Engine Control Module (ECM) does not receive a valid pulse signal from the ignition coil.
  • Common causes of a P0350 code include:
    • Faulty or shorted primary or secondary circuits
    • Defective or damaged ignition coils or coil packs
    • Disconnected, frayed, or otherwise faulty wiring and connectors
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Waqasbajwa67 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 843
