Ana içeriğe geç
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
20 Soru Tümünü görüntüle
Possible G5 graphics card replacement?
Hello! I'm was trying to pull all the data off of an old Power Mac G5, and while the computer powered up just fine (fan running, audible responses to key strokes, etc.), I discovered the monitor (an old Mag InnoVision LT976s from 2003) no longer displays anything. To be clear: the monitor powers on, and displays options, etc. But it indicates it can't detect a signal from the computer.
Undaunted, I bought some new cables (VGA to DVI, DVI to DVI, etc.), and even (thanks to this site) tried my hand at removing the (very dusty) video card, wiping it off a little, and putting it back in. No dice.
As such: is the only option here to hunt down a new video compatible with an old G5? If so, does anyone have recommendations on what to buy? Note: I only need it to help me get the data off the computer, not to work particularly well or for the long haul — so it doesn't need to be particularly nice.
Any recommendations are welcome!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You're going about it the hard way if all you want is the data. It's a serial ATA drive. Just pull the drive and put it in an external enclosure.
Here are enclosure options (make sure you get one for a 3.5" drive):
https://www.amazon.com/s?k=sata+external...
Here's how to pull the drive:
Power Mac G5 Hard Drive Replacement
Bu yanıt yardımcı oldu mu?
Puan 5
5 Yorum:
Oh! This is super helpful.
Out of curiosity, I assume it'd be a bit more work on the back end to organize the data coming off the hard drive like that, yes? (I'm not really concerned about that, just curious — I've never worked with a hard drive pulled straight out of a computer before.)
tarafından
what computer are you transferring to or reading the drive froM?
tarafından
@mayer 14 inch 2021 MacBook Pro
tarafından
You will need a way to get from the external enclosure to your MBP. This cable will do that:
https://www.amazon.com/AmazonBasics-Type...
tarafından
Awesome. Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Shalam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 196
