wifi signal strength is low and continuesly disconnect the network
wifi signal strength is low and continuesly disconnect the network how to fix?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Try using the laptop WiFi as close as possible to your network router i.e. <20 cm and check if the signal is stronger and also that the connection is stable.
If it is there may be an antenna problem with the WLAN adapter in the laptop.
Here's the servioce manual for the laptop.
Go to p.27 to view the procedure to remove the WLAN card. You don't have to remove it but this will allow you to check that both of the antenna cables connected to the card are securely connected or not.
Bu yanıt yardımcı oldu mu?
Try rebooting the router
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 64
