Ana içeriğe geç
A 250GB 3.5" SATA Hard Drive released by Western Digital.
Hdd is not getting detected
When i turn on the pc harddisk turns on and then turns off after 10-15 seconds. I want to recover my data from that disk. I tried to contact manufacturers of that disk but they say that disk is a copy and not a genuine one. I also tried to connect that drive to other pc but there also not getting detected
What should i do ?
That data is very much important to me. Please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
1 Yorum
I have already recovered some HD's by removing the electronic board and resoldering it with the hot air rework station.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@khushaldhumane explain to us what this means "they say that disk is a copy". There are two possible failures, The controller board or the mechanical part. If it is mechanical, you want to leave your hands off and send your drive for data recovery to a place that specialize in this. Those are not cheap.
For the controller issue, you could try to replace the controller board. I've done that a few times and successfully removed data from those drives. But, you will need to get the right board etc. Not always an easy find. Check this guide for what I am referring too,
Hitachi GST Deskstar HDS721010CLA332 Hard Drive Controller Replacement
If you need more info or guidance, post some good pictures of your board etc. with your Question. that way we can see what you see.
Adding images to an existing question
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Hitachi GST Deskstar HDS721010CLA332 Hard Drive Controller Görseli
Kılavuz
Zorluk:
Orta
20 minutes
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I am also stuck in the almost same situation. In this case, put your HDD in the sun for around 1 hour, then let it cool down for 10 minutes, and then insert it. In some cases, the HDD is fully recovered, and in some cases, it shows up in your PC for around 5-6 hours or a day. I recovered my data with this method.
Puan 0
Yorum Ekle
Yanıtını ekle
Khushal Dhumane sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 80
Son 30 gün: 378
Her zaman: 1,530
