Ana içeriğe geç
Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Is it possible to change ssd and other?
Hii
I have m1 pro 1tb which has serious liquid damage and the situation is unrepairable because of some layer of pcb burned. I am trying to find a solution to not dissipate my macbook pro m1 so I decided to buy m1 pro motherboard from ebay 512gb or 1tb I believe that is not a problem but my question is that if i buy ic locked m1 pro motherboard after resoldering my ssd to the ic locked board can give a life or Do i have to buy not ic locked board ? Summary of my question, is there any possibilities to bring ic locked motherboard using another not ic locked motherboard ? soldering every memory part can solve the problem ?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The M Series systems have soldered RAM and SSD storage so it’s not possible to upgrade or replace them. As far as the data on the SSD flash chips, the data is encrypted married to the systems SoC chip and TouchID unit. So transferring the chips won’t work either to gain access to the data.
While one can replace the logic board you must get the TouchID unit which is married to the given logic board and if locked to someone’s fingerprint you won’t be able to unlock it either.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Hi Dan, thank you for your answer but this video claims ssd upgrade is possible. https://www.youtube.com/watch?v=yR7m4aUx...
so if i buy 512gb version of logic board I had 1 tb version of m1 pro logic board can i resolder as the video state and can back my data ?
tarafından
@sinirsizde91397 - Rewatch the vid!
This is brain surgery! It is not something a weekend fixer can do. And unless you can program the flash with the correct code it not really possible.
tarafından
thank you ! it is somehow possible. Just need to balance of income and expenditures
tarafından
Yorum Ekle
Yanıtını ekle
Davide sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 26
Son 30 gün: 109
Her zaman: 1,378
