do not have a standby light
Hi @oldturkey03, I have the same issue as described in the original post. I have also replaced both my main board and power supply and still do not have a standby light or any activity when I plug in the TV or press the power button. I have taken the voltages on both the old power supply and new power supply while they are plugged into the wall. I measured on the connector that goes between the power supply and main board. The original power supply had voltages of .93 across the 3 middle pins on the top row. The same pins on the new power supply are at 1.12. Seems like a slight difference, but with both power supplies plugged into AC power and unplugged from the main board, I am not getting the backlights to light up like others have troubleshooted before. So I am still unable to determine if it is a bad power supply or main board. Do you have any further troubleshooting tips?
Update (09/18/23)
In the pictures, the power supply that is installed in the tv with the wires coming out of it is the new replacement board that I bought. The other picture of the uninstalled power supply is the first one that was in the TV before I replaced it.
Bu iyi bir soru mu?
3 Yorum
@thill44 we need you to clarify what model your TV is. Your original comment was posted under a AU8000
oldturkey03 tarafından
TV is a UN75AU8000BXZA
Version No : UA01 AU8000B-U75AB1
Turner tarafından
How do I access backlight led’s. I am having same problem
prasad patil tarafından
