Ana içeriğe geç
To Remove battery adhesive
Can I use hand sanitizer to remove the battery adhesive other than isopropyl alcohol?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @z9ujn6g5y5rbz5r
It is best not to.
Isopropyl Alcohol 99%+ leaves no conductive residues and also evaporates quickly.
Hand sanitizer is composed of a mixture of alcohol (either Ethanol or Isopropyl) plus other ingredients (they vary depending on the manufacturer) and they may leave conductive residues unless thoroughly cleaned away, which could be risky depending on what was then used to clean any residues off.
My view is that it's best to use the IPA 99%+ as a 1 step process. Apply a bit at a time, gently remove some of the adhesive before the IPA evaporates and so on until the adhesive is all gone. Job done.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
ı̣ɯı̣ʞɥ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 291
