shuts down with 4 blinking red lights
My XBR 65x950g started failing a few months ago. It would play for a while and turn off. Finally, and this is where it is now, the TV will start and the boot up process starts. Then the back light starts up and a second later it shuts down with 4 blinking red lights. I tried the BL_ERR pin ground trick but no luck. Same thing happens. Tried a new power board. Same thing. So is it my T-Con board? I have noticed in the start up sequence that a green light come on the middle board, then a small red light comes on and it shuts down with the 4 blinking red lights. I have a video of this sequence but not sure if I can insert it here.
Bu iyi bir soru mu?
Hi Bob,
I have this problem too and am just starting to investigate it. Any luck fixing the issue?
Thanks,
Andreas
Andreas tarafından
