Ana içeriğe geç
12 W stereo ses, Bluetooth 5 ve IPX7 su geçirmezlik özelliğine sahip taşınabilir Bluetooth hoparlör Anker SoundCore 2 için onarım, sökme ve sorun giderme bilgileri. Ocak 2017'de piyasaya sürülmüştür.
It is not charging
The speaker is not getting charged
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @naitikbohra
Does the speaker still work OK when the charger is connected?
If you can use the speaker but the battery is not charging it may be a faulty battery. Here's the Anker SoundCore 2 Batarya Değişimi guide that shows how to replace the battery.
If the speaker doesn't work when the charger is connected, have you tried a different known working compatible charger or charging cable e.g. one used to charge a mobile phone?
Use a strong light and a magnifying glass to check that the pins in the charge port connector are all there and not bent or missing, that they're all straight and parallel with each other and that there's no dust or debris in the port enclosure preventing a good electrical connection.
If everything above has been tried and it still doesn't work here's the Anker SoundCore 2 Şarj Yuvası Değişimi guide that may help.
It shows how to open the speaker so that the charge port connector can be checked to see if it is loose from the board and only needs to be resoldered back on.
If everything appears to be OK then further testing would be required to find out what's wrong.
Anker SoundCore 2 Batarya Görseli
Kılavuz
Zorluk:
Orta
15 - 30 minutes
Anker SoundCore 2 Şarj Yuvası Görseli
Kılavuz
Zorluk:
Zor
20 - 40 minutes
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Naitik Bohra sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 75
Her zaman: 1,465
