Ana içeriğe geç
Ocak 2019'da piyasaya sürüldü > Özellikler: 14 inç Ekran - Core i7-8565U - NVIDIA GeForce MX150 - 16 GB RAM - 512 GB SSD Resmi Sayfa - https://www.asus.com/Laptops/ASUS-ZenBook-14-UX431FN/ Newegg - https://www.newegg.com/utopia-blue-metal-asus-zenbook-ux431fn-ih74-mainstream/p/1TS-001A-00S86
How to fix my audio jack?
I accidentally pulled out my earphone at an angle and when I tried to put them back in the audio jack, it won't play any music. I think it should be the audio jack as the other earphones also don't work on it while when I plugged my earphones to another device, they work.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @camille8001
It seems as though the headphone jack itself may have been damaged.
If this is the case then it cannot be repaired, it has to be replaced.
The easiest option is to replace the IO USB board (supplier example only) as the headphone jack is mounted on the board.
I couldn't find a video that shows how to replace the board but here's a video that shows how to open the laptop so that access to the board is possible.
The board is visible at 1:31 minutes into the video.
Note: To avoid any possible electrical problems from occurring when working inside the laptop, disconnect the battery cable from the motherboard as soon as you can access it before doing anything else. This is shown at 1:34 minutes into the video. You don't have to remove the battery, just disconnect it. Reconnect it last thing after completing the repair, before closing the laptop
If doing this yourself is too daunting, contact a reputable, professional laptop repair service and ask for a quote.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Camille sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 276
