Ana içeriğe geç
Samsung Galaxy A22 5G, Samsung Electronics tarafından Galaxy A serisinin bir parçası olarak geliştirilen ve üretilen, orta segment Android tabanlı bir akıllı telefondur. Telefon ilk olarak 24 Haziran 2021'de piyasaya sürülmüştür. Telefon, üçlü arka kamera kurulumu ve 90 Hz ekran ile gelmektedir. Bataryası 5000 mAh kapasiteye sahiptir; bu da iPhone 13 Pro'nun bataryasından %62 daha büyüktür.
Why does my volume button does work?
I been having these difficulties in past 3 months that my up and down volume doesn't work any more?
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi @juanmigueldoton,
Has the phone been dropped or gotten wet at all?
tarafından Paylaş
Yes it's I've been drop it many times but It didn't get wet
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @juanmigueldoton
Dropping a phone certainly doesn't so it much good.
It may be that the volume problem is caused by a loose or faulty power and volume flex cable (part # GH81-20712A) or perhaps a faulty power/volume control button (supplier example only to show the button)
With regards to the other problem you're having with the headphone jack, it could be a faulty headphone jack. There's an internal spring that signals the audio control when a plug has been inserted into the jack so perhaps its intermittently operating when it shouldn't be. If this is the case then the jack would have to be replaced as it cannot be repaired. The good thing about this is that the jack is on the charge port board which is a separate module so it's easy to replace once the phone is open. The part number for the charge port board is GH81-20699A.
To find suppliers for the parts search online using the part number only. Couldn't find a part number for the control button so if it is faulty search for Galaxy A22 5G power/volume control button.
Here's a teardown video for the phone which may help.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
JuanMiguel Doton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 324
