Ana içeriğe geç
Bose QuietComfort 35 II (Model Numarası: 789564-0020), Bose tarafından tasarlanan Bluetooth özellikli, gürültü engelleyici kulaklıklardır. Cihaz bir USB şarj cihazı ve kulaklık ucu kablosu ile birlikte gelir ve iOS ve Android Bluetooth cihazlarıyla uyumludur.
Charging problem - replace Micro-USB connector?
I can't charge the headphones. Is it possible to replace the Micro-USB connection?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
I also have this issue.
With the charger disconnected I see a blue led light of the pairing that is always on.
When I connected the charger to the micro USB connector a red led light starts flashing and the blue led light continues to be on.
I already replaced the battery. I was now thinking on replacing the micro USB connector. Do you have any other idea's?
tarafından Paylaş
If you have 2 LEDs, the blue one is telling you it is on and paired. The blinking red one is telling you it is charging. If there was a problem with the connector, the red LED would not be flashing when you plug it in. However, if it is "flashing' (fast blinking) it may be telling you there is a problem with the battery or something internal.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Why do you think it is the connector? There are a number of other possibilities including the charger and the battery.
Post any symptoms you have experienced in the past.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I have several chargers.
The problem occurred suddenly without deteriorating battery before.
I can visually see the damaged connector.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Johan Varland sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 621
