Power stereeng not working
Bu iyi bir soru mu?
Check the fuse located under the dash for your electronic power steering module. If it's okay, then check the harnesses for the module itself for bad connections or corrosion on the terminals. If there are no bad connections, you'll have replace the EPS module itself more than likely.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 58
