Sunbeam PAC-259 Queen size dual Heating blanket Style G85KQ
Everything looks good, continuity good through out both sides, in both controller in preheat mode, i read 3.3 Vdc running through.... but no heat whatsoever.
Fuses good..... what should i look for to test ?
Thank you...
André,
-striving to fix everything i can... and will learn
Bu iyi bir soru mu?
6 Yorum
@andrefontaine Do you know where the heating elements are located? Those would be the next things I would check.
Edit: I think sone of those wires might be directly hooked to the heating elements. Can you test across those with your meter in ohms mode and tell me what you get?
Andrew S tarafından
added a 2nd picture, there are 4 white wires. 2 on each side of the white box. each side being a side of the bed ( queen size, 2 individual controllers). So one loop has actually 2 indidual wires. Each has continuity. i get 3.3Vdc ( + - ) when preheating.
where do you want me to measure the resistance ? ( + + ) ( - - ) ( + - ) ? i think that each loop is an actual heating element.
andre fontaine tarafından
@andrefontaine Measure each heating element with the resistance mode on your multimeter while the device is unplugged drom the wall outlet.
Andrew S tarafından
( + + ) = 14.9 ohms and same value for ( - - ) as identified on the second pictire.
What about the (+ -) resistance on both pairs?
honakrisi tarafından
1 tane daha yorum göster
