Ana içeriğe geç
The Meta Quest 3 mixed reality headset was released on October 10th, 2023 and is the direct successor to the Meta Quest 2 and in many ways the spiritual successor to the Meta Quest Pro.
8 Soru Tümünü görüntüle
Charging pogo pinout - diy replacement of dock
I want to make myself a charging dock out of the box the headset came in but I'd need to know the pinout and possible handshake I would need to mimic. Could anyone who has the dock measure the voltages and see/record and communication over the data pin?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 7
4 Yorum
i want to know the same thing as well, i already use a magnetic usb c cable but a dock would be nicer
tarafından
Me too please. Can someone take a meter to one of these docks a tell us what the pinout is?
tarafından
Just waiting for someone... anyone, to buy the dock 😆
tarafından
Hi.
Did you ever make one? if so did you 3d print it, and can you share the files?
and the schematic.
thank you
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
靠近中间的PIN是GND,靠近外部的PIN是+5V,中间的PIN通过改变对地阻值反应充电状态。我使用这个定义并完成了电路部分的demo设计。可惜的是我不擅长结构建模。
更新 (12/29/23)
like this
Bu yanıt yardımcı oldu mu?
Puan 2
5 Yorum:
只要你保证电压是5v,就不用担心简单的反接测试会烧毁设备,因为我已经试过了lol
tarafından
I don't know Chinese, please let me know if you'd prefer me to use some translator.
The inner pin doesn't matter in this case? It's enough to provide 5V to the outside pin and ground to the middle one? I tried doing this with some USB charger cables without luck back when I posted the question.
tarafından
The PIN near the middle is GND, and the PIN near the outside is+5V. The PIN in the middle reflects the charging state by changing the ground resistor value.
use a 10k pull up resistor link to the pin in the middle pin. 5v means NO CHARGING, 1.7 means CHARGING.
tarafından
The inner pin just a indicator for charging state. if I am right.
tarafından
https://www.meta.com/quest/accessories/q...
official accessory page says:
USB-C Input 9V/12V/15V
Contact Output 5V/9V/12V
so there seems it suppport charing at a higher voltage
tarafından
Yorum Ekle
Connect the wires, red to red and black to black and add a type A port to charge it
Puan 0
1 Yorum:
Which wire to which pogo pin? :) Tried checking USB 2 connection like this without luck.
tarafından
Yorum Ekle
HI.
Did you ever make one? And if so, did you 3d print it and can you share the files. I think i have a schematic but could you share what you have?
Thank you
Puan 0
Yorum Ekle
I think the same for the magnetic port. My homemade battery works
Puan 0
Yorum Ekle
Yanıtını ekle
Domi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 77
Her zaman: 1,620
