2100: detection error on HDD
It failed to start just bring word2100: detection error on HDD
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
@fik87924 that is the error that comes up when your computer's BIOS is trying to access the drive and it can't. Could be related to a bad connection between the drive and the motherboard, or it could be a bad drive. I would remove the drive and then reseat it. Give it a try. If that does not work, you may have to consider a new drive.
You can download the hardware maintenance guide for the computer you listed, from here I will help you to work on your Lenovo.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 337
