Ana içeriğe geç
A security and intelligent doorbell that live streams 24/7 and notifies you if someone is at your door.
Where to find replacement gasket?
Where can one find the replacement gasket?
The replacement of this piece is mentioned in its own guide as well as in the battery replacement guide. I have not been able to find with basic search terms.
Thank you in advance!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @kb_kb
If you can't find a replacement gasket, you may have to improvise.
Try either a suitably sized elastic rubber band or perhaps run a thin bead of neutral cure silicone sealant around the case in place of the gasket.
If using the sealant and you need to open the case in the future use either vinegar or Isopropyl Alcohol to soften it first and then pry open the case.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
KB_KB sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 150
