Why are my coils freezing up
This is a side by side model.
Freezer works fine, but fridge can't keep up.
Every 2 weeks I have to take back off of freezer section and use a blow dryer to melt ice off of coils.
Tips?
Bu iyi bir soru mu?
Tips?
Bu iyi bir soru mu?
Hi @gary87126,
What is the model number of the refrigerator?
Seems as though there's a defrost problem. This could be caused by a faulty defrost heater, faulty defrost thermostat, block drain leading from below the evaporator unit in the freezer to the evaporator pan under the compartments or a faulty defrost timer or control board.
Knowing the model number will help to narrow it down to what the problem is and also if replacement parts are required then the correct ones for the model can be shown
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 436
my freezer works fine, but my fridge frost up behind the two bottom lettuce/vegetables containers. I have to remove the back cover every 3/4 weeks and melt the frost. what is causing this problem?
Larry David Baker tarafından
@larrydavidbaker
jayeff tarafından
