Ana içeriğe geç
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
Frigidair combo dryer starts and stops after a few seconds.
Model FLCE7522AW frigidair combo dryer starts and stops after a few seconds without any sounds or beeps. What can it be? Washer works perfectly fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
5 Yorum:
@krystalcol57696 at what point does it turn back on? Immediately or do you have to wait a while? What have you checked? Could be a failed thermostat etc.
tarafından
It does not turn back on once it has shut off, only turns back on if I press the start button again and then shuts down again after a few seconds.
tarafından
Mine does the same thing. Is there a picture or a diagram of where the thermostat and fuses would be located?
tarafından
Mine does the same thing. Is there a picture or diagram of where to find the thermostat and fuses? Model FLCE7522AW3
tarafından
Most dryers would have a similar schematic. There are thermal cutouts in a dryer but no fuses. See my above comment.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Is there any sign of heating? It could be a high limit thermo. It could be a problem with the heating coils.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
No :-( since it stops just seconds after starting, there is no sign of heat.
tarafından
Yorum Ekle
Yanıtını ekle
Krystal Colon Maldonado sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 182
