Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
20 Soru Tümünü görüntüle
Black screen after battery replacement
Replaced iPhone 5 battery and it does not power up, screen is black. It does get warm with charging but nothing else. Replacement went uneventfully, I did not remove the screen, as recommended in several posts to save time and angst, instead held it 90 degrees with a band around a glass jar to hold it in place. No cables appeared broken or disconnected (took off protective plate to inspect cables but did not remove them or the screen). Hard and soft resets unsuccessful. Any thoughts / ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Based of what you said, the phone turns on because it was charging but the screen flex cables are very fragile. It may look like the connector is not damaged but inside the connector is copper wires that you cant see. you might've broke the copper inside of the connector.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Btw i was talking about the screen flex cables
tarafından
PS if you have a flashlight, shine on the screen if you can see the phone booted up
tarafından
Yorum Ekle
Yanıtını ekle
Kevin Knoop sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 81
