Ana içeriğe geç
In its first year in production, the Santa Fe was offered with one of two engine and transmission combinations. In North America, a fuel-efficient 2.4 L four-cylinder engine was standard equipment and could be mated with either a 5-speed manual or a 4-speed automatic.
gas smell hyundai santa fe
gas smell 2006 Hyundai Santa fe for many weeks is the problem in the fuel system?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@jeffreymbarnes you are not telling us where you smell it the most. Park your Hyundai on a dry flat area. Or place a large piece of cardboard and park your vehicle on it. Let it sit for a couple of hours and then check for any damp spots on the cardboard. That way, you know at least the general area. It could be the Tank, the fuel lines or any connector in between.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Thank you I will try the cardboard good idea but so far never saw any leaks when I parked the car.
tarafından
@jeffreymbarnes If it does not have a leak check the gas cap and the evap container/system (purge control valve) since this can also release the gas fumes.
tarafından
The entire bottom of tank was rusted out found good mechanic $70/hour took 4 hours to replace tank and add new fuel pump.
tarafından
Yorum Ekle
Yanıtını ekle
Jeffrey M Barnes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 99
