Ana içeriğe geç
Kapıdan buz alma özelliği bulunmayan, otomatik buz çözme ve yoğuşma önleyici rezistans anahtarına sahip alttan donduruculu Kenmore Buzdolabı 596.7857*80* modeli için bilgi ve onarım kılavuzu. Bu sayfa, 596.7857*80* düzeniyle eşleşen model numaralarına ait bilgileri kapsar.
Not getting any ice
I have not been getting any ice, I have moved the shut off arm up and down a few times and waited 24 hours for it to make ice and have not gotten any ice. I don't know where the water filter is located so I haven't changed that. Any help you can give me is greatly appreciated. thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @edbakey
If there is no water/ice in the ice maker or if it is not working, first check if the freezer door switch is electrically OK and not that one set of contacts in the switch is corroded etc..
By design the ice maker does not function when the freezer door is open.
The freezer door switch is a changeover type switch which when the freezer door is opened, it releases to turn the freezer light on and the ice maker off and when the door is closed it re-operates to turn off the light and reconnect the power to the ice maker. It is the ice maker that turns the water inlet solenoid valve on and off as required.
Be safety aware if you decide to test if the switch is OK as there is 120V AC on the switch. It may be safer to disconnect the power to the refrigerator and use an Ohmmeter instead.
If the switch is faulty, search online for 12002646 to find suppliers that suit you best.
If the water inlet valve is faulty, search online for WP67003753 to find suppliers that suit you best.
Controls the flow of water into your refrigerator for ice-making and water dispensing functions. Görseli
Ürün
Whirlpool SxS Refrigerator Water Inlet Valve - WP67003753
$73.99
Activates the interior refrigerator light when the door is opened. Görseli
Ürün
Whirlpool Door Switch - W11396033
$27.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Ed Bakey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 261
