Ana içeriğe geç
The Meta Quest 3 mixed reality headset was released on October 10th, 2023 and is the direct successor to the Meta Quest 2 and in many ways the spiritual successor to the Meta Quest Pro.
It will be Possible to do a USB-C Port Replacement?
My Quest 3 USB port is only allowing charging, plugging it on my pc it gets unrecognized but seen, for now im using adb, but i prefer when i can connect it to my pc.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
im wondering this as well, some people on reddit said that its practically impossible to replace, but it just looks like a ribbon cable
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
It certainly does seem to be possible, expecially since it doesn't look like any soldering would be required. If you search up Meta Quest 3 USB port replacement, you'll find a ribbon cable with a USB-C port on one end and an FPC plug on the other. Here's an example.
Charging Cable For Meta Quest 3 Charging Port Flex Cable Power Headphone Jack Replacement Part Accessory - AliExpress 509
So yes, it is definitely possible to replace the port; they wouldn't be selling parts for it if it wasn't. Although I didn't find any repair videos showing you how to do that specific repair, there is a teardown video that will get you all the way to removing the charging port mounted on the hinge retainer. That puts you like 95% of the way there; if you can follow the video and get to that point I'm sure you can figure out that last step.
Everything I've Learned About Quest 3 Repair + Full Teardown Tutorial - YouTube
If either of you decide to tackle this repair, I would ask that you take lots of pictures as you work and once you're done, use those to create your very own iFixit guide to replacing the USB port. It's easy, fun, and you will earn the respect of the repair community, helping those who come after you with the same problem.
Good luck and let us know how it all turns out!
Puan 0
Yorum Ekle
Yanıtını ekle
Marco Corriero sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 35
Son 30 gün: 182
Her zaman: 1,734
