Ana içeriğe geç
The Lenovo ThinkPad X250 repair page provides detailed guides on how to replace the battery, RAM, storage, and thermal paste. Additional information to help you fix your laptop on your own is also included.
Why is my laptop producing no sound
My laptop does not produce any sound even when at full volume. It is not on mute and I've tried troubleshooting and updating audio drivers
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
Hi @alvin37808,
Can you hear sounds when using headphones plugged into the audio connector on the right hand side of the laptop?
tarafından
Hi @jayeff,
Yes I can hear sound from the audio connector
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @alvin37808
Check in Control Panel → Sound → Playback and check if the Realtek digital output is enabled.
If not click on the entry → Properties → Device usage → select Use this device (enable) → Apply
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It's possible the cable to the speakers became loose or torn inside the case disassembly would be needed to clarify the problem
Puan 0
Yorum Ekle
Yanıtını ekle
Alvin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 174
