Ana içeriğe geç
Realme C25Y, Or model number RMX3259.
How to restore to factory set without password
How to reset my phone because i lost the password
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
@bisratwalelign Note: This will delete all data on the phone
  1. Turn the phone off, if it isn't already
  2. Press and hold the power and volume down buttons simultaneously for a few seconds
  3. Use the volume up and volume down buttons to scroll through the menu until you get to "Recovery Mode"
  4. Press the power button to select this option
  5. Once you see the Android in distress, press and hold the power button
  6. Press the volume up button while still holding the power button
  7. You will get to another menu. Use the volume up and volume down buttons to scroll through the menu until you get to the "Wipe data/factory reset option".
  8. Press the power button to select this option.
  9. To confirm, again select "Factory Data Reset". The phone will now perform the Factory Reset procedure.
Source
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hi @andrewsawesome,
If they had a Google account associated with the phone then they will have to know the user name and password for the account to access the phone again after the factory reset due to the Android FRP lock (factory reset protection) that has been enabled by the reset. It's a required step in the setup procedure
Either that or find out how to bypass the FRP lock
tarafından
Yorum Ekle
Yanıtını ekle
Bisrat Walelign sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 65
Her zaman: 989
