Ana içeriğe geç
E05 error and beeps - not usable anymore
After plugging it in, the LCD screen says E05 and just beeps, not allowing me to use it anymore. This code is not listed for troubleshooting in the manual. I called Breville and they said I need to ship it to them to diagnose the issue and then they will give me an estimate on the repair. Is this something I can do myself?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @bige77075
Error code E05 indicates a Triac (electronics) board malfunction i.e. a power problem.
Open the oven and inspect the control board and the power board for any obvious signs of component failure or damage e.g. burnt out or heat stressed components.
Here's a video that explains how to open it that may help.
If you spot something or you're not quite sure, post some close images of the board, in your question, to get further help. Here's how to do this on ifixit Mevcut bir soruya görsel ekleme
If you decide to replace a board here's a parts list that may help. Search online for the part number for the part (check if it matches what is printed on the board) to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Can also be caused by an over loaded circuit in your house. Breaker on verve of operating can cause the error.
tarafından
Yorum Ekle
Yanıtını ekle
Big E sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 53
Her zaman: 4,019
