Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Cannot Enable TRIM on Crucial 1000GB MX500
I recently bought and successfully installed an iFixit-purchased Crucial 1000GB MX500 SSD.
Having both attempted to use SUDO TRIMFORCE ENABLE and a complicated set of Terminal commands I found by searching online, I nevertheless cannot get TRIM to show enabled in System Report.
The command line in Terminal seems to work, but checking SATA/SATA Express shows: “TRIM Support: No”.
Has iFixit offered for sale an SSD for which the utterly necessary TRIM setting cannot be enabled? (Why would they do that?)
Or, are we (as usual) being dicked with by Apple as we attempt to maintain and repair our devices?
(MacBook Pro (mid-2012, macOS 10.14.6), 8GB RAM)
Any advice?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
If you were using HFS+ TRIM command would work! But when using APFS TRIM is already enabled, Apple does it within the file system.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
Why does System Report > SATA/SATA Express show: “TRIM Support: No” then?
(And yes, the drive is APFS.)
tarafından
@dwighthales - The act of TRIM is what’s important correct? The OS file system handles it in this case, not at the hardware level. Which is why the interface call out is NO
tarafından
Reading this (because my Crucial SSD is 3rd party), I wanted to be sure:
“Therefore, as long as TRIM is enabled on the system (via trimforce for 3rd-party SSDs, see karolus's answer), you don't have to worry about it.”
If TRIM is handled by the OS (10.14.6) behind the scenes, that’s all right, then.
I have been reading a lot online about how TRIM needs to be activated for 3rd party SSDs because Apple leaves it off for all but the SSDs it installs with the products it sells.
tarafından
@dwighthales - Contact Crucial and ask them if they offer trimforce, I know Samsung does.
tarafından
Yorum Ekle
Yanıtını ekle
dwesl sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 170
