Ana içeriğe geç
Asus E410MA-EK945TS 14 inç dizüstü bilgisayar, günlük kullanım için 14 Mayıs 2020'de tanıtıldı. CPU: Intel(R) Celeron(R) N4020 1.10GHz | Maksimum: 2.8GHz GPU: Intel UHD Graphics 600 RAM: 4GB Depolama: 64GB SSD
Laptop went off and can't switch it on. the board is getting hot
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
6 Yorum
Hi, Do your fans come on when you try to power on the laptop?
tarafından Paylaş
thank you , but this one it has no fans
tarafından Paylaş
I'd like to know if there was water damage done to the laptop, if not i think you should try booting it into recovery mode
tarafından Paylaş
@keithmazyopa Is it a Chromebook?
tarafından Paylaş
लैपटॉप ऑन नहीं हो रहा है
tarafından Paylaş
1 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@keithmazyopa start disassembling your laptop and let's see what you got going on here. Use something like this video to work on it. Once you have it disassembled, take some good pictures of the board. Then post those with your Question. It will allow us to see what you see. Also, verify that it is the board that gets hot and not the battery. Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
A hot board is a sign of high current draw. You need to ID the hot part. It could be part of the CPU power supply. That might indicate a bad CPU. If the CPU is hot, that would also indicate a bad CPU. OR the CPU PSU is putting out to much voltag to the CPU.
Puan 0
Yorum Ekle
Yanıtını ekle
Keith Mazyopa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 27
Her zaman: 879
