Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
Weak Signal after replace LCD Display
I changed my LCD assembly, just after that my iPhone have a weak signal o lost signal (no service), think i don't replace the screws at same order. Somebody help me ..! Thanks
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Please refer to my earlier post here.
Accepted Answer
Included are images of correct screw length needed.
Good Luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Hi, look carefully at this thread
wi-fi distance was reduced
and look at the pictures. It is common to forget that small silver piece which gives contact to the wifi. Let us know if that helps!
~asle
Puan 1
Yorum Ekle
check connector #7, place a tape on it just to make sure it's connected properly
Puan 0
Yorum Ekle
There is a little metal piece "clip" next to the battery connector, Also called the pressure contact. These clip has a small pin that has to be bent in order to touch the back cover of the phone. If not you will have a "No carrier" issue.
Cheers
Erik
Puan 0
1 Yorum:
[bağlı ürün eksik veya kapalı: IF182-023]
tarafından
Yorum Ekle
try a restore ! even if is the hardest way it works every time
Puan 0
Yorum Ekle
Yanıtını ekle
Georges sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 12,044
