Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Any way to replace exterior handle?
Without completely taking apart everything usually shown in breakdown videos? If not, then I'll probably just get a handle, Saw off the bits I don't need, and get some strong double sided tape, rubber cement, or strong glue to get by. Thanks in advance for any information.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I'm afraid there isn't any easy shortcut to the repair videos. The door handles are made so that you have to take the door apart to replace them; if they were easy to replace from the outside, there'd be nothing to stop you from breaking into the car by removing the handle.
It's hard to say with 100% confidence without seeing pictures or knowing exactly how your handle is broken, but I can tell you right now that there are very few ways to join those broken parts together so they will hold against the stress of activating the mechanism and pulling the door open, and nothing you've listed will do that job. Under some circumstances you might be able to get by with some epoxy-based glue such as JB Weld, but as far as repair goes, welding is the only thing that has a reasonable chance of success, but that still depends on the kind of metal the handle is made of.
So my advice is to bite the bullet and resign yourself to either not using the door or going through the whole "breakdown video" procedure. Here's one for the rear door(s); it should be close to what you would have to do on the front doors too.
How to Replace Exterior Door Handle 02-06 Nissan Altima - YouTube
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
CHAOTIC426 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 192
