Ana içeriğe geç
TCL tarafından 2018 yılında piyasaya sürülen 32 inçlik bir Roku TV.
TV twitching and double image
My TCL 65” tv starts twitching and double image after a few minutes of warming up. I replaced the t-con board but no improvement. Any suggestions what else can I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
2 Yorum
Mi televisor tiene la mitad que no se ve y a veces si como puedo solucionar ese detalle
tarafından
@juancarlos72447 that could be a bad buffer board. Check the ribbon cables first to make sure there is no rip, corrosion or etc. that may cause this. If those look ok I would suggest you try a tape-off.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@jacs46856 since you already replaced the T-con board which would be the primary suspect, the next are your LCD driver boards. Those are the boards that the ribbon cables from the T-con board connect to. In your TV's case there might be two of those (some may have four) but we would need to see those. Power your TV off, disconnect the power cable. Then remove the ribbon cable from one driver board. Plug your TV back in and try it. One half of the screen will not worki but let us know about the one that shows. Let us know if there is any change. Next try the same thing with the other side.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
No meu caso só possui uma fita não duas, como proceder?
Puan 1
Yorum Ekle
Yanıtını ekle
JACS sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 48
Her zaman: 1,376
