Ana içeriğe geç
Repair and disassembly guides and support for dish washing appliances.
Midea MDT24H3AST dishwasher error
About a week ago or so, my water lines froze, before the freeze, my dishwasher was working.
I tried last night to wash a load and found out that the dishwasher is erroring out with the delicate light flashing. From what I could find, it means drain hose may be plugged or filter may be dirty.
I poured water inside of the unit to see if it pumps out water, and from what I can see, it appears to be normal. I even sucked out as much water as I could out of the hose to see if it would stop throwing the error, but alas that did not work.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @ndowens04
Here's the service manual for the dishwasher.
Run the diagnostic tests as described on p.27 and check what error codes are shown.
The error code meaning are on p.28→p.29. The error LEDs are in a binary format. To convert binary to decimal the numbering is from right to left i.e. Binary digits decimal value = 8 4 2 1 e.g. decimal 9 = binary 1001 (8+1), decimal 3 = binary 0011 (2+1) etc. Apologies if you knew how to do this already.
If you find a part that is faulty and needs replacing (stuck overflow switch?, faulty water inlet valve?) here's the parts list for the machine. Locate the wanted part to find the part number for the part and then search online for the part number only to find suppliers that suit you best.
On p.30 there's a wiring diagram that may also help.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
My midea dishwasher kept flashing the delicate light. I was able to solve this! My main motor was leaking water and setting off the leak sensor. I fix this by replacing the motor seal.
I removed the single screw that is holding the bottom tray and could see water dripping from the main motor. The water was causing the leak sensor in the tray to stop the dishwasher. The leak sensor holder snaps loose and has a micro switch covered with a piece of styrofoam. I cleaned up the debris that had collected.
To stop the leak, I had to remove the motor and then the impeller assembly. With much difficulty I opened the impeller housing. I put some oil on the o’ring area and slowly turn the housing assembly loose with a pair of channel locks.
I found a rubber seal inside. The replacement seal is at Amazon for $4. The seal was listed for a samsung dishwasher but fits the midea perfectly. part number DD62-00053A. They say to use silicone lube on this seal and the o’ring
Not leaking now so the micro switch is staying dry and dishwasher is working.
Puan 0
Yorum Ekle
Yanıtını ekle
Nathan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 46
Son 30 gün: 184
Her zaman: 3,341
