Ana içeriğe geç
From the Inspiron series 15 model 5558 released in 2015 by Dell. A mid-level laptop with a 15.6-inch display and fifth generation Intel processor.
New battery wear level 19% in a day!
I brougt a new battery for my laptop, it wear level in hwinfo was 0% the first day and only after 2 charges it is now 19.2% in just two days.
Should I return it and get a new one?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @mohdafzal40548
Did you calibrate the new battery after you installed it?
Fully charge the battery and then run the laptop until the battery level drops to 10% and then recharge it again to 90%. Do this twice and then check if it holds its charge better.
If still no good it may be a faulty battery.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
The battery need calibration? How is that done? I tried charging the battery and draining twice. The Laptop last for 3-4 hours.
tarafından
@mohdafzal40548
Was it an OEM battery or just a compatible one?
I would get a new one given the rate of discharge that occurred.
tarafından
Yorum Ekle
Check if it's a OEM battery.
If it is not then that will be why it keeps going flat, unless it's faulty.
Puan 1
Yorum Ekle
Yanıtını ekle
Mohd Afzal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 125
