Ana içeriğe geç
Need a New Screw for Logitech MX Air Mouse
Hi...I need to replace one of the screws to my Logitech MX Air Mouse – see picture: shorter one. The screw head is stripped from wear.
Where can I buy a replacement screw, as I'm having a hard time finding something similar on Amazon and such? The screw is flat both at the top and base of the screw.
Thanks in advance for any tips.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If that is the screw, it does not look stripped to me. If it isn't holding it is likely the nut. But since the screw isn't stripped, the nut is probably not stripped either. It is probably a nut insert and may be loose in the plastic.
If that isn't the "stripped" screw, you might try looking at ACE hardware. They usually have a good assortment. It is also likely a metric screw.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thanks Bill. It’s the screw head (Phillips) that’s stripped. I should’ve clarified. I’d appreciate any tips if you have any.
I’m thinking of going to Best Buy’s repair section and seeing what they have/can do.
tarafından
Yorum Ekle
Yanıtını ekle
Curious George sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 89
