Ana içeriğe geç
Repair and disassembly information for the Logitech MX Anywhere 3 portable wireless mouse. Released in 2020 and identified by model number 910-005986, 910-005833, 910-005987, or 910-005985.
phantom clicking in Anywhere MX 3
Same problem addressed for Anywhere MX mouse, but since this model is different, I wonder if there's another solution.
This happened after around 1.5 years of use.
My partner has the same mouse and the same problem, using a different OS, so it seems to me to be a hardware problem.
Bu iyi bir soru mu?
Puan 3
4 Yorum
Hi @glicerico
What had you tried? had you tried replacing the micro switch?
tarafından
No, I don't know what the micro switch is or how to replace it. Is there a guide? If you are referring to the article I linked, I planned to do it, but saw in the comments that some people tried with the Anywhere MX 3 and didn't work for them
tarafından
Ah, I think the micro switch is the module containing the clickable part. No, I didn't replace that, I don't have the spare part.
tarafından
After I reassembled my MX Anywhere 3 mouse, when I turn on the switch, the LED at the back of the mouse wheel only blinks red. I have already tried charging it, but the red LED keeps blinking whether it is charging (with the power switch turned on or off) or not charging (with the power switch turned on). Additionally, the LED on the Bluetooth switch, which has 3 options to connect up to 3 devices, no longer turns on. Does anyone can help me?
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Inspired in the guide for the Anywhere MX mouse, I opened the Anywhere MX 3, and although it's not built the same way, the solution was simple.
After carefully removing the 4 pads in the bottom of the mouse, then the 4 screws below them, I opened the mouse and saw the white elongated button responsible for the click.
I cut 3 small squares of black electrical tape
to fit the contact point with the click button on the other side, on the top of the mouse. I pasted the 3 squares one on top of the other in the place indicated by the screwdriver:
then just reassembled the mouse cover, screws, and pads.
This fixed the problem and now my mouse works as good as new :)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yep. Same double click issue as all other Anywhere MX, appeared after 2 years of use after mandatory warranty ran out. Starting to believe this is deliberate design flaw. Has happened in 5/5 Anywhere MX mouses I have used.
Puan 0
2 Yorum:
sad situation
tarafından
tarafından
Yorum Ekle
This is a problem, why this sites never advise people to replace the microswitch. Replace microswitch for left and right click and your mouse is like new again
Replace microswitch left click
Puan 0
2 Yorum:
where do you get the microswitch replacements?
tarafından
where do you get the microswitch replacements? i don't know where to look for it because I even know its name
tarafından
Yorum Ekle
Puan 0
Yorum Ekle
Yanıtını ekle
glicerico sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 32
Son 30 gün: 132
Her zaman: 1,842
