Ana içeriğe geç
Sony WH-1000XM3 kablosuz gürültü engelleyici kulak çevreleyen kulaklık için onarım ve söküm bilgileri.
Right speaker Isnt working.
The right ear cup isnt producing any audio. The swipe functions on it still work when switching songs and pause and unpausing. Also the left ear cup does produce audio. The headphones can charge and the noise cancellation features also still work.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I assume you are speaking of wireless operation. Is it the same with cable? If yes, then It must be speaker problem.
If the rt works with cable, then it is a problem with the internal PCB.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
yes this happens both using a cable and with bluetooth. If its a speaker issue how do i fix it or is it worth buying a new pair?
tarafından Paylaş
the problems with fixing them is;
1. finding the right part
2. opening up the earphone without breaking something
3. removing/replacing the speaker
4. reassembling
Of course, you probably want to open first to berify the speaker is bad.
If you get a none exact replacement, do you have a critical ear such that you will hear the diff?
tarafından Paylaş
I appreciate the help, I'm probably going to go to a place and get it fixed there. I've had these since 2019 and I don't want to risk breaking them more. I do really appreciate your help though.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Abel Mekonen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 549
