Ana içeriğe geç
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Correct battery replacement for A1398 EMC 2745
Is Item # IF117-047-6 correct for the above mentioned laptop? I ordered and received this, but now I see the guide says "early 2013" but i think my laptop (EMC 2745) is late 2013. I thought I ordered the right one, but does anyone know?
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Replace a 8680 mAh battery compatible with MacBook Pro 15" Retina Mid 2012 to Early 2013 A1398 model laptops. 11.26 Volts (V). 99 Wh (Watt Hours). Battery model A1417. Görseli
Ürün
$79.99
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum:
The EMC number 2745 is a Late 2013 15” MacBook Pro (DG) is that your system? Double check by clicking on the About this Mac.
tarafından
I would think the EMC number etched on the bottom wouldn't lie. I don't know how I ordered the wrong battery, but luckily I double checked the procure and noticed the incorrect date range.
tarafından
@jacob14905 - So you then have the Late 2013 model not the Early 2013 correct?
tarafından
yes, thanks for your help on this!
tarafından
@jacob14905 - Just curious how it ended! Don't forget to score and accept the answer - Thanks!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
The correct battery for the late 2013 system is this one MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery and the guide MacBook Pro 15" Retina Display Late 2013 Battery Replacement
Replace a 8700 mAh battery compatible with MacBook Pro 15" Retina (Late 2013/Mid 2014). 98 Watt Hours (Wh), 11.26 Volts (V). Görseli
Ürün
$89.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
jacob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 115
