Ana içeriğe geç
Serin günlerde sıcak, yağışlı günlerde kuru kalmanızı sağlayan Patagonia dış giyim ürünleri. Onarım zorluğu, basit yama işlemlerinden daha karmaşık bölme (baffle) onarımlarına kadar çeşitlilik gösterir.
Zipper pulled away from the jacket
The zipper still works on the jacket but on one side of the zipper the material pulled away. Suggestions on how to fix it?
It seem like the seams lost their adhesive and just pulled away
Update (02/23/24)
Resim
This is the only place that I can find it. But as you can see the zipper has pulled away from the seam
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
@logandunn Can you upload a picture of the problem? Mevcut bir soruya görsel ekleme
tarafından
I updated the original post to have the picture in it
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
There are several adhesives suitable for fabric such as Loctite vinyl, fabric & plastic; E6000; Sew No More; or, Patch Attach which you might use. You might try taking two stiff wooden slats slightly longer than the length of the separation and two or (better) three clamps and, with the zipper open, spread a small amount of your chosen adhesive on the portion of the zipper that you want to adhere to the fabric (you don't want to put on so much adhesive that it squeezes out when you clamp it), put a wood slat on each side and clamp it all together. You can probably get away with using spring loaded squeeze clamps but you can use whatever clamps you have on hand.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Oh, and if there is any old adhesive remaining on the separated area, you would want to do the best you can to remove it before making the repair. It's not obvious from your picture what kind of material you're working with so I hesitate to recommend a solvent. My go-to is acetone but I would be very cautious and try a tiny amount applied by the corner of a dried out alcohol pad. A product called Goo-Gone is probably safer than acetone and is also very good at removing adhesives.
tarafından
It also occurs to me that you might try contacting Patagonia and asking them if there is a particular adhesive that they would recommend.
tarafından
Yorum Ekle
Yanıtını ekle
Logan Dunn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 47
Her zaman: 535
