The light didn’t turn on so I opened it up and noticed this was off
I only spent 15 dollars, is it worth fixing it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If that is all that's wrong with it then you can fix it for < $US0.50 + postage. (example only)
Search online for 100µF 16V electrolitic capacitor to find suppliers that suit you best. Most local electronics part stores would have these as they're a common value capacitor.
Note: These capacitors are polarity dependent so you need to solder it the correct way on the board. Usually the board has a +ve (positive) symbol printed on it showing where the +ve leg of the capacitor has to be soldered. To make it difficult (don't ask why) the capacitor manufacturers show the -ve (negative) leg of the capacitor (stripe down one side of can, with a - symbol in the stripe) and not the +ve leg, so just be aware of this when you go to solder it in.
Unfortunately I cannot see any markings on the board in the image you posted showing the +ve side for the capacitor board connection so maybe check on the underside or if none there at all, buy 2 capacitors in case you solder it in the wrong way the first time and it blows again because it was reversed.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 45
